Old 10-22-2007, 07:51 PM
thepainter thepainter is offline
1993 Caravan Overhead Console Gone Black
The overhead console of my 1993 Caravan has gone black.
Any suggestions on what it could be ?
Anyone know how it is removed ?
Thank you.
Old 10-22-2007, 10:33 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Re: 1993 Caravan Overhead Console Gone Black
What do you mean by going black?
Old 10-22-2007, 10:39 PM
It is blank and non functional.
Could it be the sensor/module ?
Where is it located and what does it look like?
Old 10-22-2007, 11:05 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
On my 96 its powered directly off the junction block (interior fuse panel) via a 10 ampre fuse. Strange as it may seem it doesn't appear it has an input from the body control module. It gets it's info from the temp sensor behind the front bumper and the powertrain control module (engine brain) on the drivers side fender wall outboard of the battery.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-22-2007, 11:38 PM
I'll check it out.
Do you know what the sensor looks like?
Old 10-23-2007, 12:00 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
It's a small diameter cylinder about 1.5 inches long on a small bracket with two wires.
Old 10-23-2007, 12:04 AM
Thank you.
I read that if one of the wires were damaged it not only would not give temp readings but the whole console would not work.
Is this correct?
If not, do you have any idea why the console is blank?
Fuses are fine.
~~~ UPADATE ~~~
I found out how to remove and repair. ( The modual is toast )
Swing back the two visors you will see 2 screws, remove them. The front of the console will drop down.
Push the console forward a bit and it will drop down. It is now hanging by two wire harnesses.
Remove the front harness, that is on the modual. The modual is held on with 2 screws, after removing them, remove the two small ribbon cables, gently pull the modual out. It is now held in by a small pivot that can be expanded to release the modual.
Put in the replacement modual and reverse the proceedure.
I called Chrysler and the moduals are no longer available for my 1993. Just as well as they are $701.00
I got the whole console from the auto wrecker for $30.00
Make sure the modual is there after removing from the wrecked van as I went through 3 before getting one that was not already removed.
