Old 10-22-2007, 06:28 PM
Poltowny 499 Poltowny 499 is offline
94 1500 Stalling
I have a 94 1500 that stalls. It usually happens when the a/c is on and it's hot outside. The truck also seems to have a rough idle. I read a couple of threads about this before but I never got the answer to the problem. If anyone can help I would greatly appreciate it.
Old 12-27-2007, 09:29 AM
briang0 briang0 is offline
Re: 94 1500 Stalling
I had the same issue on my 94 1500 with a 350 ci. I spent a lot of money at the dealer and they gave up. It turned out to be something in the distributor. I say this because I ended up going to the "Auto Recycling Yard" aka junk yard and bought a used distributor and replaced it. It's been about 6 months and the problem hasn't returned. Good Luck.
Old 03-04-2008, 11:46 AM
tagtenor tagtenor is offline
Long story short...we have a '94 Suburban. Kept stalling. New fuel pump/filter installed, No dice.
Finally had a mechanic who KNEW what he was doing look at it.
He replaced the coil and replaced all the spark plugs. It runs fine now!
Old 03-04-2008, 02:50 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Check for spark and fuel pressure when it dies. Any codes?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
