Old 10-22-2007, 06:01 PM
Micah_Jones Micah_Jones is offline
battery help
My battery died a couple days ago and i jumped my car and it started up just fine and ran normal but the battery wouldnt take a charge at all...right after i turned the car off and took the jumper cables off everything died...and today when i tried to jump it again it wouldnt even try to start..it just clicked and all the lights inside the car dimmed and pretty much went out when i tried to start it...do i just need a new battery or is there something else wrong too?
Old 10-22-2007, 06:34 PM
chase82 chase82 is offline
Re: battery help
Take the battery to checker auto parts or a place like that. They will test the battery for free and tell you if it's good or bad. That what I had to do.
Old 10-22-2007, 06:42 PM
pyrobob182 pyrobob182 is offline
Re: battery help
this sounds kinda like what happened to me. If your battery isn't charging, it is most likely that your alternator is bad.
Old 10-22-2007, 07:37 PM
Re: battery help
well this is the third time the battery has been completely drained because my door doesnt shut sometimes..so that makes the dome light stay on and that kills the battery...do batteries lose their ability to hold a charge after being drained to many times? i am just going to buy a new battery sometime and hope that works
Old 10-22-2007, 07:41 PM
Re: battery help
Also if you can take you car to checker, they are able to test your alternator while the car is running. Then you can narrow the problem down. Funny thing, my battery is doing the same thing.
Old 10-22-2007, 07:51 PM
Re: battery help
yea -- i am having somewhat similar issues right now with my car -- (see my thread above)
Old 10-23-2007, 08:25 AM
blu3kgt blu3kgt is offline
Re: battery help
yes i have heard that batteries can only take roughly around 3 hard drains... after that, battery cells inside might be damaged and won't charge properly anymore or won't even hold a charge anymore even after being charged for a long period of time.. so yes i am willing to bet you need a new battery from what you are describing
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 10-23-2007, 03:02 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: battery help
You should have the battery and alternator checked, also, make usre that the alt belt is ok.
your root problem could be the alternator but you may have to replace the battery now also.
After you ge this sorted out, fix your door or turn your dome light to the always off position.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 10-23-2007, 03:36 PM
new2mitsu new2mitsu is offline
Re: battery help
if you need an alt lemme kno
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
