| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Check engine And car useing up alot of gass
Hey guys i have a gsx mostly stock with hsk Bov Cat back, and 16g turbo the car has been sucking up lots of gas and it idels really weird it fluxuates the idel and my engine check lights on i added a ne o2 sensor the one near the turbo and another thing when i jump on my car sort of blackish color smoke is comming out im confused om going to read it throught a scanner and tell you guys the codes. thanks
Re: Check engine And car useing up alot of gass
Dude you have got to use periods. Get the cel codes pulled and let us know what they say.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
i was gonna say 02 sensor but you allready that, just check the codes, will be alot easier
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
Um...I think you need a tune/tune-up. Any type of fuel control or boost controller? And no upgraded injectors?
Hey i got the codes. i do not have any type of controllers or injectors the only up grades it hks bov running in atmosesphere, 16g turbo and cat back the codes coming up is a p1400 and p0505. the p1400 is mdp sensor and p0505 is the idle speend can you plese thell me where thses to thinks are located thanks and how much the cost to replace. i also dont understand when you get on my car blackish brown smoke come out the tail pipe. thanks
Black smoke means you are running rich. That vented BOV could be causing you some problems too. I got a few weird codes when I did that to mine, and I would stall out at a stop light if I didn't give it gas. Like said before, a tune-up would be in your best interest. Did you take a look at the plugs?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
plugs and wires are good they are pretty new is there a way to ajust the lean and rich or i have to buy a controller? anotherthing how many mpg is a gsx suppose to get? thanks
It varies but 18-21city and 25-28 highway, or in that ballpark. What year is your car?
Hey its a 95 gsx with 87000 miles and running rich dont help
