Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-22-2007, 02:06 PM
sbalgach sbalgach is offline
2003 Sentra question: Low fuel Pressure
Hi
2003 sentra GXE
CEL on with a code low fuel pressure.
Is the fuel pump in the tank? If not, where is it? Is this typically the problem for low fuel pressure? If I replace the pump all should be OK right?
Thanks in advance for any help
Steve
Old 10-22-2007, 06:17 PM
JudoJohn JudoJohn is offline
Re: 2003 Sentra question: Low fuel Pressure
there is a service bulletin regarding low fuel pressure for your year Sentra. It should be taken care of by Nissan.
Old 10-22-2007, 06:23 PM
Here is the link:
http://x.nissanhelp.com/forums/Knowledgebase/links/346
look for 052A long engine crank time.
Old 10-23-2007, 07:46 AM
Does that mean there is an 'official recall' ? Can't i just replace the fuel pump and all should be OK?
Thanks,
Steve
Old 10-23-2007, 07:57 PM
an SB is different from a recall. the SB should be covered, but it is not considered a safety issue. it does not mean you cannot replace the fuel pump. however, why use your dime, when maybe Nissan will pay?
Old 10-29-2007, 09:05 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Service bulletins do not mean a particular item is covered under warranty. Only that a problem has been identified and there is a correction for it. If you need the fuel pump repair kit, It is a 3yr and 36k miles warranty and the Repair kit will may not be covered
