Old 10-22-2007, 01:32 PM
Alex37211 Alex37211 is offline
My amp and head unit cut off completely
I have a 95 civic DX (d15)
Okay, this is what happens:
I put an amplifier in my car which drew 60 amps of current and I was pumping about 550 watts into a couple of 12's. At max volume, when a real deep bass note hit, my amp and cd player would power off completely for a few seconds. I think the stock alternator in my car only puts out 90 amps. I figure with the engine running, the spark plugs will draw a good amount plus lights and whatever else is on. And it's NOT the amp or the subwoofer wiring. It's done this with different amps and I know how to set up correct ohm loads. Is my electrical system throwing a switch somewhere from being overdrawn? I want to run about 90 amps of current just for my sound system (including one class A/B 4ch and one class D monoblock MTX and of course my head unit).
Don't I need a better alternator? Or is there another solution?
Old 10-22-2007, 06:13 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: My amp and head unit cut off completely
It won't draw 60 amps continous ......
The amp may be cutting off if the volts drop too low
Old 10-22-2007, 07:06 PM
Well how do I keep my voltage more constant?
And are you sure that is the problem?
Is it normal for the head unit to power off along with the amp? Oh and I have the amp's remote wire conected to the 12v switched wire (red) on my CD player's wiring harness. Is this okay? Could it explain them turning off simultainiously?
Old 10-23-2007, 05:01 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
do the big 3 along with a higher amp altenator and a new battery, shouldnt EVER have any problems then
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-23-2007, 03:28 PM
I know it won't be constant, but won't it spike up to that when the deep bass really hits? And doesn't lower voltage cause it to draw more amps? I put a cap with a volt meter on it once and it would go from 14 down to like 10.5 volts when the bass hit. And that cap wasn't helping at all. I think it was bad. It wouldn't hold a charge at all. Aren't they supposed to hold a charge when they are disconnected?
Old 10-23-2007, 03:51 PM
pre98zetec's Avatar
10 volts is amp frying range...
-Josh-
Old 10-23-2007, 06:13 PM
Audio Guy
most caps will not hold a charge for a long time, depends on the cap. That is correct that a lowering of voltage will increase the current draw, if you are going below 12 volts then even your battery is not floating the voltage. You may have a weak alternator/battery.
