Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-22-2007, 11:46 AM
majm majm is offline
97 LTD, hard to start when is warm
Hi,
My 97 LTD don't start itself when the motor is warm, I need to accelerate because the acceleration feels low. Somebody can tell me what to do?
Old 10-22-2007, 03:19 PM
vandok13's Avatar
vandok13 vandok13 is offline
Re: 97 LTD, hard to start when is warm
Can you explain a bit better and a bit clearer? its hard to understand what your asking
Old 10-22-2007, 09:35 PM
The 4 runner works correctly but after one hour of use feels that the acceleration of the motor is low and if I turn off the motor and turn on again, the car can't start on because seems that it doesn't receive fuel and I need to push the accelerator pedal.
I hope this can be clearer.
Thanks
Old 10-23-2007, 11:05 AM
flyguy123 flyguy123 is offline
How many miles since your last tune up?
Old 10-23-2007, 11:28 AM
Around 5,000 miles from the last tune up.
Old 10-23-2007, 01:49 PM
Have you changed your fuel filter lately? What about your check engine light, is it on?
Old 10-23-2007, 02:24 PM
Yes, I alredy change the fuel filter, and the check engine light is off.
Old 10-23-2007, 02:47 PM
Well what I would try is after the engine is warm I would pull one of the plugs and have someone crank it over, look to see what kind of spark you are getting. If your getting a good spark then I would check your fuel pressure. If its good then I would check your tempeture sensor. Just process of elimination. Hope this helps.
Old 10-23-2007, 03:07 PM
powermaster powermaster is offline
many of these types of problems are usually related to the idle air control valve
