Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-22-2007, 11:15 AM
mashbd mashbd is offline
where is the iat sensor?
1990 lincoln town car - 5.0
Old 10-23-2007, 01:54 PM
Towncar's Avatar
Towncar Towncar is offline
Re: where is the iat sensor?
Intake Air Temperature Sensor.....
I found one tech article here: http://www.lincolnsonline.com/tech/00193.html
Also:
The Intake Air Temperature (IAT) sensor determines the air temperature inside the intake manifold. Resistance changes in response to the ambient air temperature. The sensor has a negative temperature coefficient. As the temperature of the sensor rises the resistance across the sensor decreases. This provides a signal to the PCM indicating the temperature of the incoming air charge. This sensor helps the PCM to determine spark timing and air/fuel ratio. Information from this sensor is added to the pressure sensor information to calculate the air mass being sent to the cylinders. The IAT is a two-wire sensor, a 5-volt reference signal is sent to the sensor and the signal return is based upon the change in the measured resistance due to temperature.
Overview:
Removal / Installation:
Testing:
-Steven
1996 Town Car, Cartier
