Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 10-21-2007, 09:29 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Suspension...
What is the difficulty factor on retro fitting a 2nd gen CRX rear suspension setup to a '85 CRX HF?
I have the '85, plan on using it for a race car, and wanna put the coilover/independant suspension on the rear.. I have a complete parts car, so I have everything I need, and it's already been swapped for the rear discs from a '90 'teg.
Old 11-22-2007, 09:36 AM
MrWrongsalive MrWrongsalive is offline
Re: Suspension...
high
Old 11-22-2007, 10:26 AM
Re: Suspension...
yer a little late to tell me that.. and it wasn't that hard.
Old 11-22-2007, 11:35 AM
1gcvcb18's Avatar
1gcvcb18 1gcvcb18 is offline
Re: Suspension...
Did you do it or not.
84 Civic DX D16A1 Swap (in the making)
http://www.redpepperracing.com/gallery/v/1gcvcb18/
Old 11-24-2007, 12:58 PM
Re: Suspension...
"it wasn't that hard" usually implies that it's been done.
it was done, has been done, and works fine... just pretty much had to make a custom mount for the camber arm, and remove the panhard bar and replace w/ the center mount from the 88-91.. hardest part was centering that mount.
Old 11-24-2007, 01:25 PM
1gcvcb18's Avatar
Re: Suspension...
Do you have pictures of the process
Old 11-24-2007, 01:31 PM
Re: Suspension...
not of the process, next time I go see the car (it's in my friend's garage until I get the 'teg motor for it) I'll take pics underneath.. it's pretty straightforward
I'm not sure how it would be for street driving, b/c I haven't taken it in for alignment yet.. but it's in there, tires look maybe a lil off, but it's on lowering coils too... so maybe that's why.
Old 11-24-2007, 10:45 PM
1gcvcb18's Avatar
Re: Suspension...
How much did it co$t you?
Old 11-24-2007, 11:13 PM
Re: Suspension...
$20 and a six pack, honestly.. just had to pay for welding wire, and have my dad weld everything up... I mocked it all up myself. Had all the parts from a wrecked CRX HF already there, so everything went by pretty quickly... if you send me pics of the rear suspension of a 1g, and same for a 2g, I can show you the diffs, and where to put everything/what must be changed. I'll just make points on the pics and notes on the bottoms, and send them back to you. PM me if you want that.
Seriously, I think by the time the alignment is done, I'll have paid a lil over $200 for everything, but only b/c I have to have the car trailered to Sears to get it aligned, since it has no title, and will never be road legal.
Old 12-26-2007, 05:25 PM
1gcvcb18's Avatar
Re: Suspension...
So do you have pics.
Old 12-26-2007, 08:30 PM
Re: Suspension...
Nah, I actually just sold the car, b/c I couldn't get a title for it, and I wanted to make it a street car, which wasn't able to be done.. so I sold it.. honestly, I completely forgot about this thread, but if you search google, you should be able to find pics of the mod, I'm sure others have done it, since the axle beam suspension just sucks ass.
Old 01-11-2008, 08:40 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Suspension...
Your just too lazy to find out what you can do with it. In a way I wish mine was Independent, but then again, I like the fact you can move the axle around. Plus I did just learn you can use the springs off of newer struts
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-11-2008, 11:47 PM
Re: Suspension...
yes I am... and Yes, I know :P
Old 02-11-2008, 11:46 PM
avistar avistar is offline
Re: Suspension...
When you did this swap did the shock mounts work out well at the top as I don't know what the 2G ones are like. Also are the swing arms the same length? Any problem with the oem rear sway bar mounting? JS
If you need one of these send me a PM for details.
Edmonton, AB Canada
