Old 10-21-2007, 06:14 PM
infamousfuck infamousfuck is offline
3000gt TT Conversion or Other?
have a 94' base 3000gt and I was wondering.
Is it all that to get a tt conversion done..or is there something I can do to my car that will make it just as fast or even faster
Old 10-21-2007, 06:24 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: 3000gt TT Conversion or Other?
Read the Faq fuck.
Old 10-21-2007, 08:21 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
is it all what?
actually, its probably more than whatever you think. you can cut corners and forget the sensors and controls, but it will run like crap. do it right.
so you want HP for cheap? hahaahaaahahahah. best bang for your buck: Corvette.
your car can be:
-fast
-reliable
-cheap
....pick 2.
welcome to AF. read the FAQ sticky thread.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-21-2007, 08:36 PM
is it worth it?
Old 10-21-2007, 08:45 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
is it worth it?
Reading the FAQ? Yes
TT conversion? If you want a fast car, yes, but you gotta do it right. Depends how much money you have to spend and how fast you want to be.
Pics
Old 10-21-2007, 10:02 PM
Hotshot8792 Hotshot8792 is offline
couldn't have said it better myself.
I have seen way too many tt conversions blow up because someone tried to throw the conversion on as quickly as possible with the minimum number of parts as possible, then take it out immediately and romp on it, and thats all she wrote.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 10-21-2007, 10:19 PM
I know and will get all that I need for it.Im not gonna rush into things at all.Believe me,the car is in good hands.Where can I get the stuff tho?
Old 10-21-2007, 10:39 PM
dhrubio's Avatar
There's a couple TT conversions for sale on www.3si.org right now.
Pics
Old 10-21-2007, 11:11 PM
new2mitsu new2mitsu is offline
i have lots, and i do mean lots of engine parts, how much do you know about cars? i have a basically complete engine, turbos and tranny, but it may need a lil work, but i can hook you up, if you are really serious let me know
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-22-2007, 04:38 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
New2mitsu, how much would you charge as far as all the parts for a complete
swap?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 10-22-2007, 02:17 PM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
i've been researching a TT conversion myself. i'm estimating mine at about 8 thousand alone. all the parts i can name off the top of my head are here...
turbos
wastegate
bov
exhaust manifolds
exhaust system
bigger fuel injectors
bigger fuel pump
downpipe
vr-4 ECU
vr-4 intake plenium
new 8:1 pistons
new connecting rods
intercooler
y pipe
intake pipes & filters
boost controller
vr-4 water housing
water return lines
modified oil pan
oil lines
oil housing
boost gauge
AF ratio gauge
+ all gaskets and whatever...
AND THEN since you have a fwd, you would have no traction with all your added HP, so you would need nearly slicks to use around town to race with, unless you plan on racing from a roll. personally though, i always go from stoplights. i doubt you aren't doing the conversion for the power to race, because then it's going to be wasting twice as much gas.
it's worth it if you want a project that you will start and finish yourself. are you mechanically intelligent? It's worth it if you want to stand out from the rest and want to save a few hundred pounds from the vr-4. i want my conversion to be proud and say i did it myself and its not a vr-4.
you can cut corners and run boost from your stock 10:1 pistons, but you don't get much boost from that. after about 13:1= boom!
anyway, for some good news, 3sx.com is strictly for the 3000GT/Stealth. i don't know of any other online stores that are for the 3s alone. but anyway, there are hundreds of people here at AF who will be willing to sell you parts.
i fix things that aren't broken
Old 10-22-2007, 02:27 PM
VR43000GT's Avatar
^^A TT conversion can easily be done for less than $8k. What exact setup are you planning on running?
Old 10-22-2007, 02:41 PM
well this is my 1st car..what different setups are there?
Old 10-22-2007, 04:11 PM
swap?
not sure, as i dont have extra intercoolers, and what not, but i jus did mine w/ a JDM motor that only had 22k miles on it, and it runs LIKE A DREAM... i did mine for <5k
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 10-22-2007, 05:00 PM
hot3000's Avatar
hot3000 hot3000 is offline
well and dont forget I had about 3k in already for the complete rebuilt TT engine plus gauges, elec. boost controller and Apexi SAFC. I still needed the Intercoolers and piping but if you run stock on those people are always parting out their cars on 3si. I found some guy selling the piping and intercoolers for like 80 bucks once. I just needed to get someone to do the swap for me. Thats what I couldnt afford. I actually rode in a FWD TT ATX at the Charlotte 3sx Gathering a lil while back and it was soooo nice. He basically did exactly what I was planning on doing. If I didnt have other stuff going on right now I def. would have continued with the swap.
