Old 10-21-2007, 04:06 PM
weiv2000 weiv2000 is offline
Radiator fan still not working
My 98 voyager overheated/coolant leak last month, got the radiator and lower hose replace, backed on street last week, I checked the radiator fan, it came on about 1-2 mins later when I turned on the AC, I thought it might be ok, at least both fans working. Unfortunately last friday traffic hours overheated again on the freeway, coolant overflow, called AAA to tow it back home. I found out the fans never turned on without AC. I thought the low speed fan may not working, disconnect the coolant temp sensor, both fans turn on right away, stupid question...would it be bad if I just leave the coolant temp sensor disconnect? leave the fan turn on/off with the engine? I read the other thread, the temp guage uses a separate temp sensor, but when I disconnect the coolant temp sensor, the temp guage would not work as well. the guage temp only reach 1/4 high and will not go beyond
Old 10-21-2007, 08:11 PM
dcx96 dcx96 is offline
Re: Radiator fan still not working
These Vehicles Are Notorious For Bad Cooling Fan Relays, Replace That And The Coolant Temp Sensor And Your Problems Will Be Solved. You Can Do This Urself For $150 Tops.
Old 10-21-2007, 11:13 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Leaving the sensor disconnected till you get it fixed is fine. It may overcool but that's better than overheating.
Old 10-22-2007, 02:53 PM
triplethreattt triplethreattt is offline
I can't tell you how many people I know who are replacing the fan relays right now.
I just completed my replacement a few weeks ago, and my experience is in this thread...
http://www.automotiveforums.com/vbul...d.php?t=755551
Post #8 is the beginning of the actual problem and resolution...
Good luck! that relay is about $45 US at O'Reilly's.
08 Honda Fit - 45,000 miles
08 Honda Odyssey - 32000 miles
97 Lexus ES300 - 175,000 miles
*Gone, but still in the family*
98 Gr. Voyager 200,000 miles (the last 100K thanks to these forums)
May she R.I.P.
***89 Mazda 929 180,612 miles***
Old 10-22-2007, 03:41 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Been a while since I dealt with this system but, I think you can assume the relay is good if the fans turn on when you turn on the A/C. Two inputs to the PCM turn on the fans, the A/C "on" button and the coolant temp sensor. Both of these outputs leave the PCM on a single wire to the relay. Sounds like a bad coolant temp sensor or sadly an internal PCM failure. Yes no?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-22-2007, 11:20 PM
Actually the relay was replaced about 2 months ago, got it for $56 from pepboys, and today I just bought a coolant temp sensor for $19.99 also from pepboys, will install it tomorrow, hope this will be final fixed. I have already used up all AAA free tow in 2 months, next time will be charge $8 per miles
Old 01-18-2008, 11:18 AM
Unitl now the coolant fan system still doesn't work all the time. I am worrying it will overheated again when the weather get warmer, have anyone try 'Electric Fan Wiring Kits & Senders" products from jegs?
http://www.jegs.com/webapp/wcs/store...11471_-1_10113
any fan wiring kit product recommend for 98 plymouth voyager 3.3?
Old 01-19-2008, 12:48 PM
vipergg vipergg is offline
What do you mean it doesn't work all the time ? The fans don't come and stay on, they are governed by the temp sensor . Once the coolant hits a certain temp the fans should come on until the temp lowers enough to shut off the fans . Normally the fans should come on around the mid point on the guage or just slightly above mid point .
Old 01-19-2008, 03:50 PM
what I mean is when I check the fan at home, I left the engine running about 15 mins, the coolant fans turn on(without turn on AC), everything seems doing good, but once a while when I back home, the coolant is boiling and fan not running at all.
