| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I Broke something at the track
Well I was at the race track today trying to break into the 12's on pump gas before the end of the season. Well It didn't happen. I got there and took one run with a buddy in the car and missed third bad and ran a 14.1. Brutal I know but I had lost my damn tune cause I Lost power in my car and my settings reset . So I did a base tune from my first log. And went down the track again. This time I was about to shift to fourth I accidentally dropped it to second. RPM"S went over the bottom of the tachometer Im guessing 10k + and I heard this clacking noise. When I got back i noticed I had an oil leak now and my car would shake violently from about 2000-3000rpms and after that it would smooth off. Power seems pretty normal boost works. So what you guys think? I have my own suspicions on what it is but I don't want to influence your opinions.
Let me know asap By the way it shakes in every gear.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: I Broke something at the track
I'm thinking bent valves any input?
It's possible. With that wicked downshift you probably jumped the timing belt a tooth or two. Do a compression test and then don't start the car at all until you tear into it so you don't wreck anymore than you already have.
that's kinda the same thing that happened to me, so i'm gonna go and say "TRANNY".
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
