Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 10-20-2007, 02:08 PM
defrost3 defrost3 is offline
Send a message via Yahoo to defrost3
Aerostar Motor in a Taurus?
Will a 93 Ford Aerostar motor fit into a 93 ford taurus?
Old 11-12-2007, 08:25 PM
Icanfixit Icanfixit is offline
Re: Aerostar Motor in a Taurus?
I would like to know just the opposite. Taurus motor into an 93 Aerostar. I am thinking aslong has the block and heads are the same. Maybe just have to swap around oilpans and maybe the exhaust and intake manifolds.
Old 11-24-2007, 05:03 AM
C. Cleve C. Cleve is offline
Hi, Physically, It,s a POSSIBLE fit, Havbe you even given a little thought about, processor,wiring,ecm,allthe sensors, ETC !!!!!!, Man what a nightmare that would be....GOOD LUCK !!!!!!!!!!! See Ya, Clay, (retired ford tech)
Old 11-24-2007, 08:01 PM
rhandwor rhandwor is offline
Check with an automotive machine shop and make sure your intake will bolt on.
They can give you some good advice and prevent problems before they occur.
The bell housing and other parts have to match also. They hunt used parts and talk to other people who have done this or tried.
Old 04-07-2008, 12:12 AM
Fiddler_1964 Fiddler_1964 is offline
all things are possible
if the engine size and pattern of the bellhousing are the same
engine mounts,,ect
the intake and exhaust can be swapt about to make it work
the ford tech in klamath falls told me that a 99 bronco engine could not be made to run in a 85 ranger,,but it runs
depends on determination
ps,,it runs well and is still fuel injected,,7 yrs later
fiddler
Old 07-10-2012, 08:38 PM
moon03 moon03 is offline
head gaskets, intake & exaust manifolds need to be changed. head gaskets direct coolant to return to radiator its the same block and heads but the head gasket is different. not sure if any other items need changed
