Old 10-20-2007, 02:31 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Smile found hf crx what do i take
found this crx in the bone yard its a 1.5 5 spd what parts would benifite my 91 dx hatchback
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 10-20-2007, 03:05 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: found hf crx what do i take
All of them...lol. Be more specific, is there something you need? Pretty much anything you need will fit.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-20-2007, 09:11 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Don't take anything from the engine, they're all going to be worthless parts for you. Don't take the ECU unless you plan on chipping one and it's a 90 or 91...
actually, there isn't much that would be of interest to you on that car, unless you don't have all the parts for your MPFI swap yet.. then you can get the Injectors, resistor box, distributor, and a few other small parts, as well as the engine wiring harness, which will make your life much easier, if not the whole thing, just the injector harness...
Also, you might consider the seats, if they're any good, they sit lower, and are more comfy than the DX/LX seats.
Umm... I think that's pretty much it, unless you want longer gears, then you can steal the tranny too, but I wouldn't recommend it if you're looking for something snappy or "quick".
Axles are good to take, if you need them, brakes, brake parts, steering wheel, basic bullshit like that... umm... headlights and mounts, corner lights, if you need them, taillights and center panel won't fit. Bumpers won't fit, fenders won't fit, hood won't fit, get the wipers if you want them/need them, and ask about anything that wasn't already covered here.
Just realised that you said you have a hatch... so the tails and center panel WILL fit.. so you can use those too... in fact, you can use just about anything from the body... fenders, bumpers, etc.
