Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 10-20-2007, 06:53 AM
luxeryvic luxeryvic is offline
gear ratio help
can anyone tell me the gear ratio for the ring and pinion gear in the rear axel on my 77 monte carlo
Old 10-20-2007, 08:57 AM
maxwedge maxwedge is offline
A990 racer
Re: gear ratio help
No, there a different ratios. There are several ways to check this, tag on the diff? how many turns of the dr shaft to turn the wheels one revolution is another.
Old 10-20-2007, 09:01 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: gear ratio help
Gear ratio is stamped on the ring gear.
Or you can count the ring gear and pinion teeth and get the old calculator and divide ring gear by pinion teeth and figure it out.
Or post back the number of ring gear and pinion teeth.
MT
MT
Old 10-21-2007, 05:30 PM
denisond3 denisond3 is offline
Re: gear ratio help
If you only jack up one wheel and turn it, then you need to turn that wheel -twice-, and count the number of turns the driveshaft makes. If the wheel is turned twice, and the driveshaft turns 3 and 3/4 times, then the ratio is about 3.73. If both wheels are turning, then they only need to make one turn each.
