Old 10-19-2007, 05:25 PM
MoeZ MoeZ is offline
Send a message via MSN to MoeZ
91 Civic HatchBack
Hey guys i just bought a civic hatchback 91 SI and i wanted to no that, tomoro im going to buy a driver side fender for it and the fender i was gona buy is from a 90 SI hatch and im not sure if it even fits, the car looks the same but its a 1990 model.... If sumone can tell me by today that if it will fit my civic that is 91 that would be awesome and t.... plz tell me and im also buying taillight bulbs from the same person im getting the fender of.. if these things will fit plz let me no if u dotn now at im talkign about :P since im confussed too my car literally looks liek this http://akamaipix.crutchfield.com/ca/...4/DSC00168.jpg
Old 10-19-2007, 05:57 PM
stnapycnaf stnapycnaf is offline
Re: 91 Civic HatchBack
The fender will fit
Your bulbs are number 2057 ... you can pick them up just about anywhere
91 CRX HF
D16A6 Swap
Old 10-19-2007, 06:15 PM
Nick Gautreau's Avatar
Nick Gautreau Nick Gautreau is offline
Send a message via MSN to Nick Gautreau Send a message via Yahoo to Nick Gautreau
Originally Posted by stnapycnaf
1. Your vehicle is not a CRX, its a Civic hatchback
He nevewr even mentioned CRX. Read his post.
Originally Posted by Dr0pZ0n3
I just think it's funny to pull up to a redlight in a beaten 4dr against some oldie in his "muscle" car... rev the lil tiny snowblower motor against his loud ass V8, then leave him sitting there when the light turns green...
1990 Honda Civic DX - Getting custom!! Needs battery
I need parts for my car. Please contact me via PM if you have anything to get rid of
Old 10-19-2007, 06:31 PM
Dude, i swear to god ... the first couple times I read his post, it said honda civic hatchback CRX, not SI like it does now
Ohh well ... more editing for me
91 CRX HF
D16A6 Swap
Old 10-19-2007, 06:32 PM
Heheheh, i did mention it logn time ago but i did edit .... it was by accident lol i wrote crx ahahha :P srry... btu i actully changed it to civic hatch... btu yea tnx for the fender help but i dont get it ... is tthat a yes for the bulbs...? or no?
and i wanted to ask sumthign else.... the bulb or fuse for my gauges is nto working at night i put the light up full but it wont show its still dark... what do i need to fix that?
Old 10-19-2007, 06:36 PM
as far as the bulbs go, you should probably ask him what kind they are, as far as the bulb number.
the light problem could be a fuse or the bulbs in your cluster have burnt out. You can disassemble the cluster and I believe the bulbs for that are 194's [same as your corner lights]. Check the fuse first, lol
you might also want to check all of the wiring plugs behind the cluster.
91 CRX HF
D16A6 Swap
Old 10-19-2007, 07:56 PM
cool... tnx alot man
Old 10-19-2007, 11:06 PM
hey guys.. i jsut checked that.. reverse lights work, when i put braiks on the light works, indicator lights work.. and hazzard light work from the back... when when i turn the light on for night it works for front but the back is not working.. Just needed to knwo again what it can b ... the wiring or the bulbs are gone?
Old 10-20-2007, 12:12 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Alright, for most parts if your skeptical on what years will fit, your safe getting from a 90-91...88-89 had some minor changes in styling, so some things won't swap over.
For the lights....are you talking about in your cluster? If your not getting anything there, are you getting any lights on your heater controls too? If not, its either a fuse or wiring...I'm having this issue right now as well. All my exterior lights work, just the interior lights aren't working, which I'm gonna check everything when I go and replace the heater core since Ill have everything out again.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-20-2007, 01:44 AM
i didnt really notice that much on the heater light but my gauges light wont work and as i said above ur post "TONY" abotu my tail light
Old 10-20-2007, 12:20 PM
Tony's Avatar
TLD Member #1
Man, seriously, its hard for me to understand your posts. So all the lights are working except for your taillights and gauges? Brake lights, headlights and everything else are working?
I would check your heater controls and see if they are lighting, that will tell you if its gonna be just your gauge cluster, or all your dash lights.
Tony
Old 10-20-2007, 06:31 PM
well yea heater lights wont work also.. so im nto sure wats wrong now:S... yea yea brake lights are working indicator lights are working but the night light when u turn car on wont work
Old 10-20-2007, 06:59 PM
Tony's Avatar
TLD Member #1
Sounds like its either the wiring or a fuse, check all your fuses first. When I get back under mine, I will tell you what wire powers your dash lights. I know its a red wire that plugs in on top of the fuse box, I believe its like the 5th wire from the right on the bottom of the plug(its a grey plug). Just testing I had mine working, but when I went to jump a power wire over to it, I couldn't get them to light up again, so Ill have to figure something out. I know on mine Im just not getting any power to that wire at all, I just haven't had the chance to take everything out and find out whats going on.
Tony
