Old 10-19-2007, 04:26 PM
dulley dulley is offline
2001 brakes
a freind of mine has a problem with his brakes ,sometime the peddle will get real hard ,and when you get close to stopping the abs will kick in ,no abs lites or anything. hes replace all rotors and pads ,fluid changed .i told him sounds like the booster,
thanks
bob
Old 10-21-2007, 04:28 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: 2001 brakes
It very well could be the Booster, but not sure that would explain the ABS comming on. Sounds like the ABS sensors might be going bad.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 10-23-2007, 04:24 PM
j cAT j cAT is offline
Re: 2001 brakes
hard pedal is the booster or vacuum line is leaking.or possibly a check valve in line with the booster put vacuum guage in line with the booster line and with long enough vac hose moniter the vac. while driving . because you say it does not happen continuosly.
