Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 10-19-2007, 01:29 PM
3100guy 3100guy is offline
95 Mystique scan tool
Hi, does anyone know what kind of scan tool is used for a 95 Mystique with the 2.5L six cylinder from Mazda. I've seen one for Fords and Mercurys up to 95 the the Mystique model is for 4 cylinders only. Any help would be appreciatied, Thanks.
Old 10-20-2007, 07:56 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 95 Mystique scan tool
The 2.5L in the Mazda is not the same 2.5L used in the Contour/Mystique.
The Mystique came with both I4 and V6 engines in all model years.
If you have a 95, you have OBD-I. You dont use a scan tool like OBD-II. Instead you count the flashes. See FAQ on contour.org on how to get codes.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=10
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-22-2007, 01:49 PM
Thanks for the info. Actually I thought as much as I already bought the OBDI scan fool for Fords up to 1995 but thanks for confirming that it's the right one. I have one other question and that is the plug for the scan tool which is located driver side near the firewall has wires leading into the plug holes - is this normal. I haven't seen another plug which looks the same any help would be appreciated.
Old 10-23-2007, 04:15 PM
Does it look like the one I posted in the link?
"The CEG Nazi"
www.contour.org
Old 10-25-2007, 07:28 PM
Yes it does. thanks
