Old 10-19-2007, 07:57 AM
blu3kgt blu3kgt is offline
Lsd
well last time i was on 3si and seen the advertisement of the limited slip differential(lsd) and i was just wondering if anyone had purchased it here or just pros and cons of it and if it really is worth the money.... i have a sohc and when i peel out i do notice that only one wheel is spinning....so if you get the lsd, both tires would spin then right.... so will this mean that you might see better 1/4 mile times??
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 10-19-2007, 09:05 AM
mistermoonpie mistermoonpie is offline
Re: Lsd
only one wheel spins as in the other one is completely still? Can it do that?
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 10-19-2007, 09:27 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Lsd
Yep you got the right idea. As for whether it's worth it or not...I don't consider any engine mods on an N/A "worth the money". But that's just my opinion, if you're happy with how fast the car is now and just want a little faster launch, then it might be worth it to you.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-19-2007, 10:42 AM
Re: Lsd
only one wheel is spinning but as the car launches forward the other wheel just follows along, it doesn't just stay still
Old 10-19-2007, 10:57 AM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
Re: Lsd
how much is the lsd? and is it 1, 1.5 or 2 way? clutch or gear type?
i fix things that aren't broken
Old 10-19-2007, 07:01 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Lsd
LSD is around $1k.
If you dont plan on any hardcore racing I wouldnt get it. I am about to get one, but thats only because I;ve broken 2 diffs. One I broke in May due to wheelhop. One I broke in Sept on the launch. I've narrowed it down to probably being worn bearings on the diff and the shock load of the launch caused the diff to "jump"
