| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Resin Calipers
Hi everyone. Long time wanderer, first time poster. I'm looking for some resin calipers for an Enzo I'm working on. I already have all of the photo etch, just not the calipers. Any help would be greatly appreciated.
Re: Resin Calipers
Welcome
![]() You could modify the kit callipers? A post in the classifieds thread may help you find somebody willing to part with some?
Re: Resin Calipers
I'm pretty sure hat I saw Tang working on exactly this- as set of resin calipers made from the kit parts, designed to be used with PE rotors. I thought Crazy Modeler was intending to use them as masters for a caliper set they were going to sell, but don't know if that happened. Tang would be the best person to ask.
On the other hand, to may bear mentioning that the plastic kit parts in the tamiya Enzo are magnificent. Sure, they don't have the ventilated edge detail that a PE sandwidch has, but the Enzo has covered wheel arches- so even with the wheels off that's a detail that is nearly invisible anyways. Given a good paint job (and a bit of appropriate weathering), the kit parts would in no way look inferior to a PE replacement. When I get around to my Enzo, I have no plans to replace the brakes- I'll save that kind of work for a build where it can be better seen and appreciated afterwards. ![]() Oh, and welcome to AF!
PHOTOBUCKET SUCKS |
Re: Resin Calipers
Hey, I was just thinking the same thing a couple days ago.. I need to find enzo calipers too. If I can't, then I'll have to mod the kit brakes.
@MPWR: I'm planning to leave one of the wheels off to show off the PE brakes and calipers.. I finally realized why I got my SMS sup detail enzo kit so cheap... the seller removed the resin calipers provided... ...I don't have a mill or lathe, so I was wondering if any of you had suggestions on how to mod the kit calipers to fit the PE brakes?
Please read the following linked articals before posting a question. Once you have and still have questions, try to post your questions clearly. This will make a lot of people's blood pressure drop back to normal, including mine. NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST AF Car Modeling Tutorial, How-To and Product Review Depository AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0 And finally,I wish you all happy modeling
Re: Resin Calipers
The resin calipers in the SMS kit are just resin copies of the Tamiya calipers.
Mike |
Re: Resin Calipers
my common sense tells me to use a bit drill to make rough holes where needed then clean up with a fresh sharp knife/blade. How else would you do it?
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
Re: Resin Calipers
Re: Resin Calipers
even better; quicker and cleaner but with a little bit more risk.
so there you have it, two ways depending on what tools you have.
Re: Resin Calipers
- popsicle stick with sandpaper glued on - Dremel with thin grinding wheel - PM to someone with a milling machine ... Does that help?
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
Re: Resin Calipers
Thanks guys for the replies. Gave me a few alternatives that I didn't think of.
Steve
Re: Resin Calipers
SMS sells the calipers seperatly via mediamixhobby
Johan
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris. ![]()
Re: Resin Calipers
Re: Resin Calipers
Thanks for all of the replys and suggestions. I checked the mediamixhobby website and the resin calipers are out of stock. I originally tried to cut off one of the calipers from the kit brakes, and that didn't turn out so well. My Enzo has been shelved out of frustration of getting the brakes right. LOL I think I might have some extra kits with the same brake calipers that I'll try to cut out and see how that goes. I'm finishing up a Supra that I've started in the mean time, I'll be sure to post that project in the WIP area.
