Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-18-2007, 09:23 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Plug wires flashing?
Okay so I had my hood popped tonight. It was pretty dark outside and I noticed little flashes coming from my plug wires. Looked like the flashes were coming from inside the plug wire jackets. The arc flashes were coming from inside the wires and each wire was flashing at different times at different spots but, not very fast. Every few seconds there would be a faint flash. My questions is, is this normal? I honestly have never looked at my plug wires in the dark and saw this before. My wires have been on for awhile now so I don't know if they may be going bad or if this is normal occuring event.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 10-18-2007, 09:27 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Plug wires flashing?
Thats not normal, might want to check into that some more
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-18-2007, 09:34 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
They're arcing because they're worn out. If you looked closely at them, I bet you can find some tiny cracks. Get new ones.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2007, 09:36 PM
NateS's Avatar
Thanks I figured it wasn't normal but, I didn't want to go spend $80 bucks for no reason.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 10-18-2007, 09:43 PM
How old are they? For the power that you're running (by your mods), you might want to look into Buschur's COP (coil-on-plug). They're pretty spendy, but basically what it does is each sparkplug gets it's own "mini-coil" that sits right above it. I know a guy that runs them up here, and he said he could definitely tell a difference when he put them on, but he kept having troubles with arcing plug wires so he got the COP instead.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2007, 09:51 PM
MazdaX's Avatar
MazdaX MazdaX is offline
or go with silicones..not as good as the COP's but eh..not as pricey either. You can get 10 mm's off ebay for around 40.00 shipped :/
2004 Mazda 6i
1997 Tahoe
Old 10-18-2007, 09:52 PM
NateS's Avatar
I'm ussually kinda cautious about those ebay deals but, I'll scope it out.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 10-18-2007, 09:55 PM
If you do go wired again, definitely get oversized ones to keep this from happening again anytime soon.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2007, 10:19 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i had the same problem with mine, but mine is only one wire, like if i pull it a litle then you will see/hear sparks. and my sparkplug wires were brand new. I will get oversized wires next time. l
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 10-18-2007, 10:36 PM
Maybe you just got a bad set. A new set shouldn't do that right out of the box, you have to wear them out at least a little bit before they start to spark.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2007, 10:39 PM
Holset powered 420a
Were these wires from ebay??
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-19-2007, 06:39 AM
no man, i bought them at checker auto, but now that i remember, they said they had limited lifetime warranty.
-MODS-
Old 10-19-2007, 06:52 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Yeah those are definitely no good. I had the same problem with the Firebird going through a lot of plug wires until I upgraded to heavier ones... So with my Talon I just went and bought heavier ones off the bat rather than screwing around with stock wires...
Although now I am wishing I had gotten a COP setup for my motor... Who knows, maybe that'll be next on the list of things to do once its running.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-19-2007, 02:26 PM
NateS's Avatar
Thes plug wires I am talking about are bigger ones. They are Magnacore 8.5 mms. Like I said though the flashing seems to be coming from inside the jacket. It is not arcing out of the jacket jus inside.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 10-19-2007, 02:30 PM
So it's not arcing outside through the jacket? I'm confused now. So you could see little sparks from INSIDE the wires?
Do you or someone you know have a multimeter? Check resistance on the wires, it should be less than 22,000 ohms.
95 Talon TSI AWD
97 Eclipse GST
