Had My Car Scanned.. And
I Took my car to get it scanned regarding all the service engine soon poppin up and my car starting to tremble..
well the reader didnt read my PCM.. and the tech told me that once the service engine light comes on.. it stays on even if the battery cable is disconnected..cause my SES stays on and it comes off... he used two machines to try and read it and it didnt connect.. and i took my car in to get it scanned a year ago at the same place with the same machine.. so it has read my PCM with no problem.... the tech told me it is most likely my PCM has gone bad.. because it cannot be read and it acting up.. anyone know if this could be right???.. anyone know if the PCM is expensive??.. |
Re: Had My Car Scanned.. And
And this is what year?
1994 Buick Lesabre..
You could very well have a PCM failure; however, even if you do replace the PCM, the new one could fail if you do not correct the original problem. All relays and solenoids need to be verified for proper operation, prior to replacing the PCM!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
ok.. i heard they are expensive brand new.. i was told to go to a junk yark and look for one..
now if i do that.. do i need to get off a 94 lesabre?? |
I just replaced the PCM on a 94 LeSabre last week. I looked at the JY and eBay (JY) and the used ones (with a 30-day warranty) were 50-65 bucks plus shipping. I then found a rebuilt unit in stock, at my local O'Reilly Auto Parts for 99 bucks and it included a lifetime warranty. That decision was a no brainier!
Where is the computor located on the 94 lesabre
It is inside the car to the right of the glove compartment. It's easy to get at, you have to unscrew the black plastic cover that is under the dash on that side. I think i had to remove the glove compartment door, and a couple of light and an airbag connector to get it out. It's about 8"x8"x2" and has 3 connectors color coded red,white and blue. make sure it's bad before you replace it as it's expensive.
Good Luck Good luck. |
