Old 10-18-2007, 05:14 PM
budster2 budster2 is offline
changing inside door handle 03 accord
Trying to replace the drivers side inside door handel on a 03 Accord. Got hte handle loose from the door, but the handle is attached to a cable that is hard to grasp to change. If you lose the cable, it goes inside the door panel and is lost unless you take entire door panel off. Does that need to be done? thanks
Old 10-19-2007, 09:56 PM
mpumas mpumas is offline
Re: changing inside door handle 03 accord
Is it a cable or metal rod? Earlier Hondas used a metal rod held to the door realase with a plastic snap clip.
Old 10-28-2007, 12:19 PM
It is a cable and seems to be stretched pretty tight - wouldn't want to drop it inside the door
Old 10-29-2007, 08:29 PM
Based on http://www.hondaautomotiveparts.com/...ONT+DOOR+LOCKS the cable is inside a exterior casing, so if you can grab the casing the cable will not go very far. To grab it you can use something like hemostats, or clamping pliers.
