Old 10-18-2007, 08:16 AM
userpete1037 userpete1037 is offline
Shock Absorber
I own a 95 chevy truck(350, 5.7L) and I'm hearing a noise coming from one of the shock absorber(driver's side) that has the kind of sound when you open an old door. I sprayed some WD-40 on the joint areas which did the trick for a while but now it's doing it again. Is this a sign of it going bad?
Old 10-18-2007, 03:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Shock Absorber
Rubber bushings will do that as they get old. As long as it's tight, I'd either let it go, or keep spraying it. I would use a silicone based spray, not petroleum based, over time the rubber will get soft.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-27-2007, 08:44 PM
Re: Shock Absorber
I'm curious, the splash shields under the fender are bent outward tremendously. Could this be a sign of shocks needing to be replaced? Plus the boot around the upper balljoint on the pssenger's side is torn. Could this cause any problems? Should i replace it?
