Old 10-18-2007, 12:54 AM
tman7 tman7 is offline
93 Astro rough accelleration
I got a check engine light and I started noticing poor/rough accelleration with my astro van so I had a friend check the codes.
45 Oxygen Senser Rich Exhaust
54 Fuel Pump Relay or Circuit fault
I replaced the O2 Senser. No change. Then replaced the relay, still no change. The codes seem contradictory; if the relay isnt sending enough voltage to fuel the pump than wouldnt the mixture be lean?
Does anyone have any suggestions as to whats going on?
Thanks
Old 10-18-2007, 06:34 AM
CD Smalley CD Smalley is offline
Re: 93 Astro rough accelleration
Do you have a W or a Z engine? Look at the 8th digit of the VIN.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-18-2007, 02:41 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
tc 45 on mine was from a missfiring cylinder pumpin unburnt fuel thru and running real rough, check you ignition system. mine turned out to be the distributor but it could be anything in the ignition system
