Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-17-2007, 09:55 PM
brute1976 brute1976 is offline
trans swap
just wanted to know if anyone knows if a 95 5 speed trans will work on a older 350.and if no why not.i thought i could just change the bell houseing and make it work
Old 10-18-2007, 02:53 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: trans swap
It probably "can" work with some modification. But you really should be looking for a T56 six speed from a V8. The 5 speed (called the T5) is the one for the V6's, and from what I've heard it can not handle alot of power without being built up.. which in the long run would cost more than just getting a 6 speed. I also believe that the input shaft on the T5 is either shorter/longer, and possibly won't work. Can't be sure. Can only recommend you look for a T56 instead.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
