Old 10-17-2007, 06:43 PM
Mark_Pacheco Mark_Pacheco is offline
1997 C3500 7.4L P1345 code
Engine rebuilt by shop 700 miles ago. Replaced MAF sensor, downstream O2 sensors, now getting P1345 code. Engine clicks when cold, hard to start when at operating temp and blows black smoke when it finally does start. Runs fine when cold, struggles on acceleration when at operating temp. Suggestions?
Old 10-18-2007, 10:29 AM
777stickman 777stickman is offline
Re: 1997 C3500 7.4L P1345 code
P1345=CKP/CMP correlation. This means the crank position sensor and the cam position sensor are out of phase. Most likely cause is the dist is one tooth off on either side. Also need a high end scanner capable of getting into "cam retard" or "cam offset" mode to set timing (0 +/- 2 degrees @ 1000 rpm).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-20-2007, 08:30 PM
Question Re: 1997 C3500 7.4L P1345 code
Makes sense to me. The only thing that I wonder about is why the error wouldn't show up prior to 700 miles of being driven. Also, I had two rich fuel mix codes show up prior to this error. I figure if the cam is off by a tooth, it should have registered before, or at least, when the rich fuel error did. Or am I misunderstanding how these newer engines provide codes?
Thanks!
Old 10-21-2007, 06:21 AM
Jeremy-WI Jeremy-WI is offline
Thanks!
It could be the effect of the distributor not being set perfect after the rebuild and the wear on new parts. I would consider the rich codes just another side affect of the distributor not being right. There have been cases of extreme distributor gear wear but I don't think any of those had less than 50k miles
Old 10-21-2007, 10:30 AM
Here are some more things that can cause this code.
1. A loose CMP sensor in the dist.
2. Excessive timing chain play.
3. Loose rotor on the dist shaft.
4. Loose or missing dist hold down bolt.
Need the rich DTC codes to try and help with that.
57 Chevy 210
