Old 10-16-2007, 08:09 PM
rsmith8411 rsmith8411 is offline
Clunk in Steering
I have a 96 C3500 and it has a weird "clunk" in the power steering that only happens when I first start the vehicle moving. It does it one time and then doesn't do it again until I let the vehicle rest for at least 5 minutes. If I stop for gas, it will do it when I restart the vehicle moving or any other such time after it rests. It is definitely not a whine or a belt type noise - it's a metallic type clunking noise. Suggestions for what this could be?
Old 10-17-2007, 03:28 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Clunk in Steering
It only happens when you start moving, or when you first turn? If it only does it when you first move, try shifting between drive and reverse a few times and see if it does it then. It would probably be a loose U-joint if it is when your first start moving.
If it really is in the steering, I assume you checked the balljoints, tie rod, drag link, wheel bearings, and the gear box to make sure it's tight against the frame?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
