Go Back   Automotive Forums Car Chat > GMC > Savana
Old 10-16-2007, 03:42 PM
johnny11 johnny11 is offline
check engine light and starting problem
Hi all, My first post need help. bought 99 GMC savana 5.7 check engine light stays on trouble codes P0171 and PO174 system lean and also sometimes I'm having starting problem, fuel pressure 60 psi ignition on and then drops to 20 pci but if i turn the ignition on again jumps to 60 psi.
Thank you for your help advance.
Old 10-16-2007, 06:32 PM
maxwedge maxwedge is offline
A990 racer
Re: check engine light and starting problem
Welcome to AF, pump is bad or the press. regulator " spider" assy under the plenum is leaking, very common.
Old 10-17-2007, 01:43 PM
Max, thankyou for reply. it was the fuel pump.
