Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-16-2007, 04:18 PM
divemaster divemaster is offline
98 Transport Climate fan control resistors...
Hey all - me again...
I just bought a new resistor bank for the climate control fan - as everything fan wise does not work until levels 4 and 5... Problem is - I can't find the darn thing. I assumed it would be on the firewall near the fan housing - but it is just not jumping out at me.
Has anyone changed this and could tell me where to find it??
Thanks in advance,
Shane
Old 10-16-2007, 04:55 PM
Re: 98 Transport Climate fan control resistors...
Sorry!! Cancel my last - I found the darn thing... 5mm socket!! ??? whoda thunk it... hmm. GM??
Old 10-17-2007, 03:04 PM
aamirmali aamirmali is offline
Where is the resistor located?
Did you change it? Did it fix the problem?
Where did you buy the resistor and how much were they?
My brother's van is doing the same thing...
Old 10-17-2007, 04:07 PM
inafogg inafogg is offline
1. Remove the under-dash panel on the passenger side
2. Remove the blower motor (this allows easier access to the resistor assembly)
3. Disconnect plug from blower motor assembly, and disconnect plug from blower motor resistor assembly
4. Remove resistor assembly screw closest to you, and undo 2 screws closest to firewall (it is not necessary to remove these, as the resistor assembly has slots, not holes, for these screws to pass through. This allows you to tilt the closest edge of the resistor assembly downwards and remove the resistor assembly.
5. Install the new resistor assembly, and reverse the above steps.
*screws have 6mm hex head - I used a socket and small ratchet (1/4 drive) to do the job - it worked well.
Old 10-18-2007, 01:24 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Here is a link of a picture of the location:http://autorepair.about.com/library/a/1h/bl251h.htm
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 10-20-2007, 07:58 AM
I bought it at Napa - $43.00 canadian.. and yes it fixed the problem! Prepare to have a sore neck and save yourself the aggrivation - take out the 3 screws that hold in the blower fan and take it out first...
Old 10-20-2007, 07:59 AM
actually - do EXACTY what inafogg suggests - he has it down to an art Thanks all!
Old 10-20-2007, 04:22 PM
thanks glad to help!!
