Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-16-2007, 02:38 PM
rloya99 rloya99 is offline
1998 saturn
i have a 98 saturn that the low coolant light turns on i repalced the reservoir with the sensor and it still turns on i also replace the sensor for the temp gauge and still turns on any ideas thanks
Old 10-16-2007, 02:56 PM
tim007 tim007 is offline
Re: 1998 saturn
check connections and make sure ur radiator is topped off??
Old 10-16-2007, 03:03 PM
Re: 1998 saturn
it has plenty of fluid topped thanks
Old 10-16-2007, 03:07 PM
Re: 1998 saturn
was reading on another site and they said some times u get air bubbles and it may take a few days to work them out
Old 10-16-2007, 03:10 PM
Re: 1998 saturn
also says to chek to see if it is getting power...if its not getting power to the senser u will get a fault code
Old 10-22-2007, 02:11 PM
Re: 1998 saturn
now the service light came on does does anybody knows how to reset it thank to answer ur question yea there is no power to the resv sensor thanks but this light com on thanks
Old 10-22-2007, 04:07 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: 1998 saturn
Go to autozone and get the code scanned. Replaced the ECTS yet?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 10-23-2007, 12:22 PM
Re: 1998 saturn
i'm sorry but what is the ETCS thank u
Old 10-23-2007, 12:23 PM
Re: 1998 saturn
codes came up with P0172 PO711 P0741 THANKS
Old 10-23-2007, 01:47 PM
Re: 1998 saturn
Trouble Code: P0172 (1.9L I4 VIN 7 Std)
Fuel Trim System Rich (Bank 1)
Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
FUEL Details
MIL Details
Trouble Code Conditions:
DTC P0105, P0107, P0108, P0112, P0113, P0117, P0118, P0122, P0123, P0125, P0128, P0201-P0204, P0300, P0301-P0304, P0336, P0440, P0442, P0446, P1403, P1404 and P1441 not set, engine speed at 500-4000 rpm in closed loop, ECT sensor from 140-239ºF, IAT sensor from 10 to 176ºF, calculated airflow from 2-80 gm/s, MAP sensor from 30-90 kPa, BARO sensor over 70 kPa, TP angle under 75%, and PCM detected the Idle Speed and Cruise fuel trim cells were -21.1% with the current Short Term fuel trim under 0%.
Possible Causes:
Base engine "mechanical" fault affecting one or more cylinders
EVAP system component has failed or canister fuel saturated
Fuel delivery system supplying too much fuel during cruise or idle periods (e.g., faulty fuel pump, or faulty pressure regulator)
Fuel injector(s) is leaking or stuck partially open (one or more)
HO2S is contaminated, deteriorated or it has failed
MAP sensor is out of calibration (check the MAP sensor signal)
Trouble Code: P0711 (1.9L I4 VIN 7 Auto)
TFT Sensor Signal Range/Performance
Number of Trips to Set Code: 1
CCM Details
MIL Details
DTC P0113, P0114, P0117, P0118, P0711, P0712, P0713, P0722, P0723 and P1792 not set, ECT sensor over 160ºF on the previous startup, ECT and IAT sensors within 10ºF at startup, IAT sensor less than 104ºF, and the PCM detected the TFT sensor indicated 16ºF more than the IAT sensor right after startup (fault detected twice).
Possible Causes:
ECT or IAT sensor is out-of-calibration or "skewed"
TFT sensor is contaminated, damaged or "skewed"
TFT sensor signal or ground circuit has a high resistance fault
PCM has failed
TSB 01-07-30-022 contains a repair procedure for this code
Trouble Code: P0741 (1.9L I4 VIN 7 Auto)
TCC System Malfunction (Stuck Off)
CCM Details
MIL Details
DTC P0336, P0716, P0717, P0740, P0743, P0745, P0756, P0758, P0761, P0763, P0766, P0768 and P0789 not set, no Speed Shaft, Noise or VSS codes set, engine started, vehicle driven at cruise speed at an engine speed over 908 rpm, TFT sensor more than 68ºF, TSS signal over 224 rpm, TCC applied for 5 seconds, and the PCM detected that the speed difference across the torque converter was more than 280 rpm (i.e., TCC was stuck off) for 7.5 seconds.
Possible Causes:
Converter charge valve is stuck causing the TCC "apply" pressure to be exhausted to the lube circuit
Converter limiting valve stuck open
Input shaft O-ring or torque converter O-ring leaking
TCC apply circuit internal damage or low main line oil pressure
Torque converter is damaged or it has failed
TSB 99-07-30-018 contains a repair procedure for this code
ECTS: Electronic Cooling Temperature Sensor. The stock unit installed in the factory was made of nylon and is one of the most common issues with the S-Series car. It has been known to cause idle and/or coolant issues. Run a search here. $20 part from www.saturnparts.net that all Saturn owners need to replace if not already. Did you replace the entire reservoir tank? Check the level when cold. These cars are indeed picky about the coolant level.
