Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-16-2007, 02:30 PM
Siouxicide Siouxicide is offline
98 GS-T Spyder top problem?
The motor for the top works fine, the top goes back fine, but there's a bar(above the front seats when up) that binds on the interior in the back by where the seatbelt goes into the inertial reel. If it didn't bind there it'd go down and up perfect, but right now I have to help it. The bar looks "bent" but seems as though if it were straight the top wouldn't operate right. The bar, about 1"x8" if it were straight, is shaped like a parabola right now. How do I keep this from binding? I did a search but the other threads I've read seem to be a different issue.
Old 10-16-2007, 02:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 98 GS-T Spyder top problem?
Check around the tech section of dsmtuners. There is a few articles over there that should be able to help you.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
