96 lincoln towncar ... wont start
bought the car 2 weeks ago .... intake manifold was cracked .. and a head gasket was blown .... changed both heads and gaskets. changed intake manifold .... changed water pump... .... car started as soon as i put everything back together.... after i got it running .. i drained all the anti-freeze and changed the spark plug wires ..... when i changed the wires i just toke them off ,,, i didnt take one off at a time and replace it with a new one... i toke them all off at the same time .. i checked the owners manuel and went with what the book said ,.... but now car will not start .. cranks ...... little ,water in the spark plugs ...... do i just need new plugs ...let me know what u think .. thanks
Re: 96 lincoln towncar ... wont start
whoa, are you saying that theres a lil water in the hole you put the spark plugs in? that doesn't sound good, but about the not starting issue, did you put the plug wires on in the correct firing order? what book did you use that tells you the firing order? what motor does your car have in it (size/type) ?
i think if you put the plug wires on in the correct order you'll be alright, but the water on the plug sounds like a serious problem, maybe you didnt put the new gaskets on correctly/ they didnt seal properly? is there any coolant/water in the oil? check your oil and make sure there isn't any coolant/water in it, becausee if there is and you attempt to run it/start it serious damage to the motor could occur, and water/coolant in the oil means you didnt put the gaskets on correctly and you have an internal leak
97 lincoln town car signature |
