Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 10-15-2007, 10:20 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
SAFC on a non mass air flow sensored engine
I've been wondering about this for a while. We have a '90 civic hatch we are working on and we have a spare SAFC 2. We are about to start the turbo process and need fuel management. It would be great to use the SAFC 2 on it, but the swapped d16z6 (i think thats what its called...im not a honda person) doesnt have a mass air flow sensor. So at first I thought that it just wouldnt work because in my mind a safc is just pointless because the thing that it controls (the MAF sensor) isnt there. But, alot of guys on here run safc's on 420A's which IIRC have no MAF sensors. So how does this work?
*EDIT* I didnt think about the sub forums. This should probably go in the performance section. Sorry.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-15-2007, 10:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: SAFC on a non mass air flow sensored engine
It uses the MAP sensor off the intake manifold. On mine, the MAP wire at the ECU is split; one end goes into SAFC, other end comes back and goes to ECU. MAP and MAF are basically the same thing, just work a little different.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-15-2007, 10:54 PM
Ok. then so what would I set it as? Like hotwire, karmen or what?
Caleb
vanilla gorilla
Old 10-16-2007, 07:34 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I think you set it to pressure.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-16-2007, 10:26 AM
david-b's Avatar
Dave is THAT guy
I believe that's right. Haven't looked at it in awhile, but it sounds right.
75 Monte Carlo
Old 10-16-2007, 02:25 PM
Ok then. Thanks for the help.
Caleb
vanilla gorilla
