Old 10-15-2007, 09:08 PM
Saytin Saytin is offline
2003 Sunfire Bogs down in 2nd and 3rd Gear
I have a 2003 sunfire 5 speed with over 200 k when I take off in 1st gear its ok then when I shift into 2n and boot it it bogs down. Then I take off the gas then give the gas slowly its fine out new fuel filter on it still does the same thing. Has any one got any Idea's please
Old 10-16-2007, 10:43 AM
1991tercel 1991tercel is offline
Re: 2003 Sunfire Bogs down in 2nd and 3rd Gear
how old are your plugs? cat?
Old 10-16-2007, 07:45 PM
The plugs have about 150 thousand on them changed them today and its made a big differance But is still a slight miss but it is better
Old 10-17-2007, 08:27 AM
You might have to changed out the o2 sensors as well. that may help you out
Old 10-17-2007, 04:34 PM
Ok thanks I will look into that all so Went to the dealership they said nothing would show up on the scope as my service light is not going on
Old 10-17-2007, 05:02 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if you had an o2 sensor problem of ANY kind your check engine light would be on
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-18-2007, 03:46 PM
J-Ri's Avatar
J-Ri J-Ri is offline
That's rediculous. Take it to another shop. The scope can show even a very small problem, whereas the SES light takes quite a bit to turn on.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
