Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 10-15-2007, 05:24 PM
markkri markkri is offline
Timing Belt got replaced
My Toyota Avalong XL 2000 got a new timing belt.
With the original timing belt the normal idling speed was 1000 rnd/min, with the new one it dropped to approximately 750 rnd/min. Plus I feel some shaking. Plus I feel a few 'brr' sounds when I turn off the car. What was done wrong?
Old 10-15-2007, 05:27 PM
emt1134 emt1134 is offline
Re: Timing Belt got replaced
either they did not properly line up the gear teeth when installing the belt, or they installed something that they had to remove, incorrectly.
Old 10-15-2007, 08:39 PM
Thanks. Is that kind of work for a high level mechanics only?
I got my old belt, and the box from the new belt. That is a 'Conti Synchrobelt Kit'. The label on the box says 'TB257K1. Replaces:
Gates: TCK257
NAPA: 2522571
Goodyear: GTK0257'
Could you, please tell if the kit is right for Toyota Avalon 2000?
How to proove to them that something is wrong?
Old 10-15-2007, 09:43 PM
I am not sure what kit is the right one. I would bring your car back to where you got the work done, and tell them something isn't right.. They should fix what they did wrong.
Old 10-18-2007, 04:23 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
750 rpm is a good idle speed. Whatever is wrong, it is not the idle speed.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-23-2007, 07:21 PM
denisond3 denisond3 is offline
I worked on an Avalon V6 (1995) that had one bad fuel injector. It was noticeable as soon as you put it in gear to drive around, and I could tell it was misifiring at an idle. But... the idle speed before the repair and after the repair was exactly the same. Just smoother with all cylinders working. I also replaced the timing belt and the two pulleys. That didnt change the idle speed at all. The computer was choosing the idle speed, not me. You might have a sticking throttle plate, or a poorly adjusted throttle cable, or a sticking idle air control valve. Those would affect the idle.
