Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-15-2007, 04:38 PM
glee glee is offline
97 bravada 755 code
how do i replace the shift solenoid b ?
Old 10-15-2007, 06:13 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 bravada 755 code
The solenoid pack is attached to the valve body, remove trans pan to access.
Old 10-17-2007, 03:45 PM
so how do i know wich is a and wich is b?
Old 10-17-2007, 05:53 PM
nevermind i got the solenoid b changed and its woking fine thanks for the reply.
but as luck would have it when i was working on the trany i found a coolant leak coming from the back of the motor.
i looked at the heater hoses but they looked good .
ran out of daylight so couldnt find leak.
any idea where to check ?
freez out plug maybe?
Old 10-17-2007, 06:53 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
The GM plastic intake manifold gasket strikes again. It can't be less expensive for the factory to buy than a paper gasket that lasts for decades so I guess there's another reason GM engineering put a plastic gasket on the lower intake manifold...planning for the future I guess, future gasket failures.
It put a Jeep Liberty in my yard.
Old 10-17-2007, 10:17 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Tell me it isn't so! I've had a few Jeeps from the '47 CJ-2 to the '57 CJ-7 but I gave up on the new Jeeps when they got bought by AMC and later Chrysler. You'd be better off buying an old Willy's rust bucket and building it back up than driving a Chrysler. Probably cost less too.
Old 11-05-2007, 05:20 AM
ok got the intake gasket changed (9 hrs)
finaly got to drive it after i changed out the shift solenoid b weeks before.
anyways i still get the 755 code and the car does not shift right when i first drive it,i dont know if when the car warms up or me shuting it off a few times is fixing it but it will work. just not all the time.
if i shut the car off for a few seconds it will start out in first gear and then it will (for lack of a better word ) pop out of first and go in to third. i shut the car off 3 times this morning one one my road,it started out fine then poped out, second time at atm started out fine then poped out, third time at gas station, it worked fine all the way to work. i wonder if its a loose connection. any idea?
Old 11-05-2007, 07:56 PM
AF - Advisor
Talking Re: 97 bravada 755 code
Ok Eric, I'll 'fess up...we were looking for a replacement for the '97 Bravada and was looking at a '98. It had a junk transfercase that they wouldn't make me a swinging deal on so we looked at some other vehicles. I walked past the Liberty, looking at a coupla Rainiers, a Trailblazer and a Dodge SUV(I can't recall the name right now). After basically "striking out", I looked for my load leveler and she was still standing next to the Liberty , so I asked if she was ready to leave and she said she liked the Liberty. Well long story short and 31 years of marriage...she got her Liberty. At least it has a real mechanical AWD and no vacuum lines...like an early Bravada.
Old 11-06-2007, 11:40 AM
no ideas?
Old 11-06-2007, 07:51 PM
AF - Advisor
I'm in the 1997 Factory Service Manual..I see a P0753 1-2 Shift Solenoid Elactrical AND a P0756 2-3 Shift Solenoid Performance....no P0755, please advise.
Old 11-07-2007, 05:11 AM
i dont know chris all i have is a autozone print out and it says solenoid b cricut open or shorted.
the 755 i think i seen here as solenoid b code so i might be wrong.
i do know that once the car warms up and i shut it off 1 time it will work fine.
Old 11-07-2007, 05:14 AM
by the way thanks for the advice on the intake gasket it took care of my coolant leak. good call
Old 11-07-2007, 05:26 PM
AF - Advisor
Here's something that helped a trans problem I had once. I forget the DTC but the trans slipped like it had a race converter and the book said check the fuse then check for wires at the trans that might have nicked insulation...mine was fine.
Then the book said check the 20 wire connector on the passenger side of the transmission. Mine felt tight but I wiggled it tighter anyway. After resetting the DTC, I drove the car and the trans worked normally...for the next 7 years.
Old 11-10-2007, 02:05 PM
jharris26 jharris26 is offline
i had a similar issue, can't remeber the error code number, but took the transmision pan out and unbolted the next part up from that and took that into a transmission repair place. they told me they seen a lot of s-10's and bravadas with this issue. he took out a pin or solenoid out and reemed out the hole it went into and put in a stronger/bigger part in and its worked just fine since then. thats been 2ish years ago
