Go Back   Automotive Forums Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 10-15-2007, 03:35 PM
Murray Kish Murray Kish is offline
Getting Old...
Hex Bolts
OK.... first question for the FAQ....
I'd like to make some small hex bolts. I thought it would be pretty simple, but I must be doing something wrong...
I have some brass hex rod (small, not exactly sure of the exact size since I'm at work right now.... ) and I figured the lathe would easily cut a rounded section to represent the threaded part of the bolt, and then I'd just part it off. Or, just slice off a piece of hex rod to act just as a bolt head that would be surface mounted...
Well, the brass basically just deflected on me and wouldn'd cut properly. I had the cutter running pretty close to the chuck, but really couldn't get it to work out like I hoped.
Perhaps just too small?? I'm guessing about 1- 1.5mm diameter brass hex rod. I have steady rest, but fail to see how that would help here? Is this a job for the follower rest? (of course, that would be about the only stinkin attachment I DIDN'T buy with my order..... )
Murray
Old 10-15-2007, 03:38 PM
freakray freakray is offline
AF Modelrater
Re: Hex Bolts
What speed were you rotating the rod at?
AF User Guidelines
Old 10-15-2007, 03:43 PM
Getting Old...
Re: Hex Bolts
Not very fast. I didn't pay too close attention, but most of the stuff I've been reading (from the Sherline propaganda....) says decrease speed, increase feed. So generally I've been in the bottom third/half of the speed control....
Should I wind it up and try high speed?
Old 10-15-2007, 06:06 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Hex Bolts
I've had no problem cutting aluminum and brass bolts. I cut them "backwards". The shaft facing the tailstock, and the head towards the head stock. I also only cut a length of the shaft a few millimeters at a time. About 3mm at a time. So if the bolt is 9mm long, it will require three stages of 3mm long cuts at a time.
Those are some tiny nuts/bolts I've cut before out of 6061.
-Mike
Old 10-15-2007, 07:16 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Hex Bolts
You fiend, where'd you get the small dia hex rod? I've never been able to find it.
Turning small diameter rod is a bit of a learned skill. More than likely, you will need to do any cutting and parting very close to the chuck jaws- maybe with in 1/4" or so. Run the speed up fairly high, and take very light cuts. Be slow and gentle when moving the cutting bit. A live centre or steady rest isn't really going to help you. Learning to do small diameters is really a finesse thing as much as anything else. I seem to remember there's something about turning small diameters in the Joe Martin book, too.
Hey Mike- are those nuts cut to a hex head? How'd you cut that?
PHOTOBUCKET SUCKS
Old 10-15-2007, 07:27 PM
cinqster's Avatar
cinqster cinqster is offline
Re: Hex Bolts
Someone on the board suggested recently that K&S do it but I've not found it in the UK so far. Must admit I hate working with brass and have also had issues with thin bar.
Old 10-15-2007, 10:22 PM
mike@af's Avatar
Re: Hex Bolts
1/32" Ø Hex nuts. They were cut by making an index out of some 1/2"Ø Hex stock I had laying around. Basically, I made a force fit tool that the nut was lightly pressed on to. Milled it out. Popped it off with my X-Acto, and continued the motions until done.
-Mike
