Go Back   Automotive Forums Car Chat > Ford > Sierra
Old 10-15-2007, 02:59 PM
sierra2.0 sierra2.0 is offline
2.0 carb dohc off a cylinder!
i have a 2.0 dohc carbed sierra. It is off cylinder 4, closest to the gearbox, i have just replaced the spark plug leads and plugs and this has not helped. any one know what could cause this?
Old 10-15-2007, 03:20 PM
inafogg inafogg is offline
Re: 2.0 carb dohc off a cylinder!
''It is off cylinder 4'' im not sure what your question is
Old 10-15-2007, 03:35 PM
sorry i mean that the cylinder is not firing. the cyclinder nearest the gearbox
Old 10-15-2007, 04:07 PM
what year & mileage
Old 10-15-2007, 04:32 PM
dohc glx 2.0 with standard weber 2v tld carb, think its 1990. sorry dont know the miles engine was swapped. i would add that it does not idle very well. there is oil coming from the back of the engine between the head and the block. however the water and oil are not mixing
Old 10-23-2007, 07:55 PM
rhandwor rhandwor is offline
I would check for a broken valve spring or a worn lobe on the cam shaft. Check compression in this cylinder.
