Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-15-2007, 12:01 PM
RieSh RieSh is offline
Drivers side window won't open
i have a 93 cutlass ciera and the passenger side window won't open. the other 3 work just fine the only thing is that i have to open them using the switches on each door. the master switch doesn't work. i just got this car from somebody else that told me that there is power going to the switch.
Old 10-17-2007, 08:28 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Drivers side window won't open
Welcome to AF.
Pull out the switch and check for your self for power at the drivers door.
Check the plug in for corrosion, clean it if necessary.
Could be that the motor has just died...
Heres a link for repair manuals..
http://www.autozone.com/shopping/repairGuide.htm
1999 Grand Am SS 3.4 OHV
Old 10-18-2007, 02:12 PM
ok there's power to the switch. but if the motor doesn't work does the switch stop working?
Old 10-18-2007, 02:34 PM
inafogg inafogg is offline
no it sounds like 2 problems.1 if you have power to d/s motor & it doesnt
work your window motor is bad.2 if the other 3 windows work but only
with switch on ea. door then the master switch(driver control)is bad
Old 10-19-2007, 01:42 AM
JohnDD JohnDD is offline
Sounds like the problem I had on my 91 Old Cutlass Ciera. Problem was that a wire going to the master switch was broken in the hinge area. You need a ground from the master switch for the other windows to operate. Make sure the Master switch has a ground. (not just power).
Old 10-22-2007, 01:13 PM
yeah that was it. a cable in the hinge area was broken. thanx
Old 10-22-2007, 06:57 PM
good call john
