Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-15-2007, 09:52 AM
bossie1cow bossie1cow is offline
1994 GMC Z71 OXYGEN sensor
Hi, can aninopertive O sensor, shut the throtlle body jets off?
Old 10-15-2007, 01:58 PM
2000CAYukon 2000CAYukon is offline
Re: 1994 GMC Z71 OXYGEN sensor
No. If the ECM detects that the O2 sensor is not working, it will set the Check Engine Light and run in Open loop (instead of Closed loop where is uses the 02 readings to adjust fuel).
Ignition module and/or pickup coil can affect the fuel injectors. As the dist turns, the pickup coil sends an AC signal to the ignition module that is converted to a DC signal. This DC signal is used by the ECM to fire the injectors.
//2000CAYukon
