Old 10-15-2007, 06:39 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Code P0141 help, which part? on a 4 cyl Sunfire
I'll ask here instead of the Cavalier/Sunfire threads in hopes of a better answer.
I'm getting an intermittant P0141 code, HO2S Heater Circuit Bank 1 Sensor 2, on my daughter's '97 Sunfire.
This is the heated oxygen sensor after the catalytic converter, the 4 wire unit. The light comes back on after 7-10 days after I reset the code.
So how can I tell if this is the sensor, or a plugged converter?
The part itself is $90.00, has about a 6 ft wire harness, and the connector is under the intake manifold (hard to get at- I can't quite see it), while a true fit converter is almost 3 times that.
Car runs fine, just a little bobble when first started while cold- about 10 seconds of rough fast idle. No smelly exhaust.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 10-15-2007, 08:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Code P0141 help, which part? on a 4 cyl Sunfire
The code is for the sensor heater circuit.
Not a cat or sensor operation.
Check wiring and voltage to sensor heater and for good ground.
Some also have a fuse on 02 sensor heater circuit.
MT
MT
