| Latest | 0 Rplys |
| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
Show Printable Version | Email this Page |
#1 | |
I just install the 18 inch wheels and tires on my 98 honda accord coupe V6 EX . and i think it still little bit higter than i expected. I am planing to lower my car in oder to look better. If once i had lower my car, Would it affect the aligtment or cambet of the my car? I am very appreciate if anybody could give me an answer!! And also how many inch should i lower my car?
#2 | |
Re: Qusetion about lower my car!
Can anyone answer my questions? thx a lot!!
#3 | |
#4 | |
if you lower your car either professionally or have someone do it you will still need it to be realigned so either way you look at it. your gonna have to realign it
but i dont recommend doing it yourself especially since you have custom tires they are more expensive to replace if you do lower on your own so my advice professionally have it done |
#5 | |
Do u mean i can lower my car at where i had changed my rims and tires?
#6 | |
![]() Join Date: Oct 2007
You should look at suspensions that are available, and they will tell you how much it will lower it. If you want to be able to adjust the height you will need coilovers.
Good luck. |
#7 | |
you will need a camber kit you can buy it from aspeed shop or make your own using metal washers just remember it will need aligned when done or you will be buying tires in about 5000 miles and maybe a set of ball joints as well!
#8 | ||
#9 | ||
Kind of a Big Deal
2. Im a bit amused with your user name.... what happens when you guys break up? runaround |
#10 | |
So how much would i spend on lower my car?. i saw some of lowering spring are really cheap in ebay?..Shall i buy those in ebay or just go to find some prefessional to do that?
#11 | |
![]() Join Date: Jul 2002
If youre going to buy on Ebay, make sure its from a good brand such as Eibach, H&R etc. Do not buy generic 'no name' parts. You need to do ALOT of research before you trash your car. An example of what I have for my 96 Civic:
H&R sport springs 1.75 front lower and 1.5 rear - $180 KYB AGX adjustable dampers - $400 Omni power front/ rear camber kit - $250 4 wheel alignment - $50 (got a deal) This plus a swaybar gives me all the handling I need on the street. Remember that with 18" wheels on your car the ride will be a little rough. Lower ride heigh means you need higher spring rates to keep from bottoming out. Read this: http://www.tirerack.com/about/techcenter.jsp Here is a pic of my car:
96 EJ6. Future home of boosted B18C1.
#12 | |
Can i just buy the springs and install on my car?
#13 | |
Kind of a Big Deal
yes, but you will still need an alignment
#14 | |
And it will bounce and your shocks will probably die.
