Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 10-15-2007, 12:32 AM
blade09 blade09 is offline
Exclamation 95 SLS white smoke coming out the exhaust
I have a 95 SLS with 78,000 miles. Every time I start the car and let it idle for a while, 5 minutes of less the white smoke begins to come out of the exhaust. After the engine warms up the white smoke disappears. Is this normal for a 4.6 northstar engine?
Old 10-15-2007, 06:14 AM
DFBonnett DFBonnett is offline
Re: 95 SLS white smoke coming out the exhaust
It may just be condensation. However, keep a watch on the coolant level. If it drops, consider the possibility of a failed head gasket. Have you had any overheating problems?
Old 10-15-2007, 02:52 PM
I didn't have any problems with overheating, one time the coolant level dropped but I added some fluid to it and it hasn't been a problem since. ITs been couple weeks ago
Old 10-16-2007, 06:24 AM
Just keep an eye on it then. If the gasket is bad you'll lose coolant. If it's been two weeks with no loss, you're probably seeing condensation.
Old 10-31-2007, 08:05 PM
thank you very much. appreciate your help
