| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Engine topics!
So I've been thinking about the motor rebuild and thinking what I want to do. There's ups and downs of everything and I'm trying to decide which is best for what I want. Originally I was going to stroke the motor to a 2.2, but then the turbo will take longer to spool, correct? Why? I always won't be able to build a high reving motor then too right? Why's that? Why is there a difference between that with a stroked motor and an non-stroked motor? Leaving it as a 2.0, I can get revs high and spool time quicker, but isn't that going to hurt the motor more then? We all know how much these things fall apart to begin with. So which is better to do? If there seems to be so many downs with stroking, then why do so many people do it?
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Stroker, High reving, spooling...
The more displacement the SHORTER the time it will take a turbo to spool.
This mainly applies to 4G63's but the info is still relavent. http://www.dsmtuners.com/forums/showthread.php?t=271451
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
wow great article.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Boner!
Stroker = faster spool, less revving
Stock = slower spool, higher revving EDIT: Edited for retarded post. Destroker does NOT increase spool time. Last edited by gthompson97; 10-15-2007 at 05:01 PM. |
I dont think the destroker spools any slower than a 2.0 does it? Theres no reason it should, afterall it has more displacement than the 2.0.
But why would someone perfer high high rev over quick spooling? Or vise-versa?
![]() Quote:
And I'm sure I don't have to explain why people stroke for quick spooling. |
I read a great article the other day that said "its better to make power at higher RPM to take advantage of gearing" It all comes down to preference and use. If your building a pure track car thats only gonna see less than 3k rpm at the beginning of the race isnt it better to have your power band reach higher. If your building a DD that makes absolutely no sense becasue itd be like drving a D series civic all day unless you drive like a maniac and drive to redline from every stoplight.
1995 GSX 2Gb bumper Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5 /Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs ![]() Wish list: CAMS |
well... you can have a high reving stroker its weather you build your engine enough to be able to take the abuse. They do make 7-bolt strokers that can rev to 8k, but on the flip side of that you are going to need a turbo and cams that will support that kind of power. Having a stroker would be more of a if you are planning on running a super huge turbo where spool time is a big factor. For someone with a evo3 for ex that would be a bit over kill sure. Sure you would spool the turbo instantly but it would not be able to flow enough to stay with the motor, so in that case its would be more suitable for someone with a stock displacement to take advantage of that.
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
Higher rev limit means you can take spend more time in lower gears over the course of the quarter mile. That means a greater percentage of the track spent at higher acceleration rate. I've posted a lot on this topic in the past. Almost every top ET DSM is running a 2 liter. To spool a big turbo on a street/strip car though, a stroker can really be the way to go.
I ran my regular 2.3 combo to 8k rpm all day long, no real issues. Above that though and you're better of with a long rod motor (2.4 block, 2.3 pistons, 162mm rods). I've heard of people with Magnus long rod motors going to 9k. Destrokers are an interesting option. 2.1 liters with a more favorable rod ratio than a regular 2 liter. There are some funny piston speed dynamics to consider though, which have been blamed for the 2.1s lack luster performance in many cases. I'm not sold on them yet.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
So it has a lot to do with the fact that gears 1-3 are more of acceleration gears. You want to stay in those as long as possible on the track, but for street and DD use it wouldn't make sense right?
So, since my car is a DD and will see the track every now and then, stroking would probably be good if I go with a large turbo? Any specifics on what size would be large then?
Dont waste your time stroking the 420a. You would be better off to drop a 2.4 in it. Its not that much more work and im sure you would make more power.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
What are you goals with the car as a turbo? With that we may be able to point out a better turbo for your applications. Also have you given any thought to what SilvrEclipse said about the 2.4 4g64? I mean that would be almost just as good as you having a factory turbo e-ride
1991 GSX 2.3 Stroker |
