Old 10-14-2007, 07:01 PM
steve__p steve__p is offline
97 battery draining
hi,
my battery keeps draining while parked. i removed the positive cable and there is >10V with the key of and doors closed. i pulled each fuse and can't find the bad circuit. I removed the light timer relay hoping it was the culprit but still the issue is there.
Any ideas what to do next?
steve
Old 10-14-2007, 07:40 PM
old_master's Avatar
Advisor/Moderator
Re: 97 battery draining
Testing voltage for parasitic draw is not an accurate test. Amperage draw must be tested. GM specification is 1200ma maximum draw. Voltage draw less than battery voltage is due to "keep alive memories", such as clock, radio, PCM, etc. Check the amperage draw and post your results.
