Old 11-29-2002, 10:28 AM
yalvonne's Avatar
yalvonne yalvonne is offline
Question legacy amps??
Does anyone know how good or bad American Legacy amps are?? I found a legacy 2000 watt amp for around $150. Is it a deal or a rip off?
Old 12-23-2002, 09:12 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
again, you usually get what you pay for. Name brand equipment is usually more expensive, the specs are much more accurately stated, and the equipment is generally far more reliable over the years.
Old 11-26-2003, 11:25 PM
BusterHymen BusterHymen is offline
Re: legacy amps??
I had a legacy 200W amp, till recently. it lasted VERRY well. Untill I installed a biger ground wire. apparently a 2000W amp will push about 14,000 watts across 2 twelves @ 1/4 ohm. who knew?
Old 11-26-2003, 11:27 PM
Re: legacy amps??
It lasted over a year actually. ( again, till I pushed it WAY too far)
Old 11-27-2003, 08:22 AM
Audio Guy
well, let's see (per channel)
200W @ 4 ohms
400W @ 2 ohms
800W @ 1 ohm
1600W @ 1/2 ohm
3200W @ 1/4 ohm
that's a lot of power out from an amp .... the protection circuit should have kicked in, when it sensed the very low load.
Old 11-27-2003, 10:02 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: legacy amps??
I personally don't like legacy, but I had someone that I met who had a really good sounding legacy amp hooked up to 2 12"s ported. so I don't know. These were rockwood twelves. All cheap stuff and it sounded pretty decent.
Old 11-27-2003, 10:50 AM
loismustdie loismustdie is offline
legacy is shit, and so is pyle, pyramid, and crunch and profile just to name a few.
legacy is actually renound as probly the most popular of the ''cheap brands'' to put it mildly.
but my friend has said some of the legacy subs have bumped nice in the past, but i will garantee that the amp that says 2000watts, which is max. is not putting out that sort of power, and most amps don't usually ever put out their max power, but their rms power rating is a different story.
i have not yet found a legacy rms power rating anywhere. if i were you i would buy a rockford fosgate(mainstream brand) or an avionixx(non-mainstream).anything but the ones i listed at the top.
just curious what are you pushing that requires 2000watts.
i mean c'mon, these pretzels are making me thirsty.
the aquabats are seriously the best band in the world
Old 11-27-2003, 01:49 PM
Haibane's Avatar
Re: legacy amps??
Profile California are actually very well made. I don't know where you get your info from, but I am sure many others would agree that profile are great amps for the cost
Old 11-27-2003, 05:49 PM
yeah dude your right, i meant to type somthing else. i guess my ind just wandered. after i read ove what i said i was like, "why the hell did i put in profile"
