Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-14-2007, 04:43 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Top End
Anyone have any ideas to add some top end to my RS that will be somewhat of a resonable price? If it means doing some internal work i will do it.
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 10-14-2007, 06:45 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Top End
I see you have listed custom exhaust, but does that include an aftermarket header? If not, a 4-1 design would improve top end, 4-2-1 design will give you a little top end and a little torque.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-14-2007, 07:51 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Top End
Reasonable like what? Couple grand?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-14-2007, 09:57 PM
Re: Top End
I would prefer not to spend that much, but if i have to i will.
Under The Hood:
Interior:
Old 10-14-2007, 10:00 PM
Re: Top End
No it doesnt have a header, but i am getting a megan racing 4-1 header & full 2.5 or 3in exhaust to replace whats on there, there is a high flow cat and a can on it --> thats what was on it when i bought it...
Under The Hood:
Interior:
Old 10-14-2007, 10:09 PM
david-b's Avatar
Dave is THAT guy
Re: Top End
You don't have to do anything?
My head cost me over $2,200 for a complete build (yes I counted everything). So that should give you a ball-park figure.
75 Monte Carlo
Old 10-15-2007, 10:37 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Top End
Just do all the bolt ons and see if thats enough for you. You say you want top end, like you want to go 140mph? Or you want the car to be quicker in the high rpms?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-15-2007, 11:42 AM
david-b's Avatar
Dave is THAT guy
Re: Top End
Oh... I thought he meant top end engine work. My bad.
75 Monte Carlo
Old 10-15-2007, 12:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Top End
Don't go any bigger than 2.5" for the exhaust. 3" will just hinder performance.
95 Talon TSI AWD
97 Eclipse GST
Old 10-15-2007, 02:23 PM
Re: Top End
Thanks for the exhaust tip, and i was more looking for a higher top speed and a little more power in the higher rpm's and possibly a little more torque. Up to about 120mph, the car goes great, it has pretty good acceleration and enough power to make me happy, but it would be great to break that barrier and hopefully be able to hit 140 someday soon like you said. I seem to loose a good amount of power once i hit 120. Any ideas?
Under The Hood:
Interior:
Old 10-15-2007, 03:57 PM
Holset powered 420a
Re: Top End
The motor doesn't have enough power to get to that high or speeds. There is really no reason you should be going that fast. I have been stupied and done it to but if you get caught at those speeds your done for. And all that weight your adding with the sterio isint helping you.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-15-2007, 04:26 PM
Re: Top End
With the trunk i purposly designed it for the fact that it was going to be lightweight, removing the spare and the jack, i really didnt gain more then about five pounds from what i figured out. I built it using a frame of 2x2's and screws, and then covered it using a lightweight sound-proof foam, and i have black suede ariving probably tomorrow, to cover it all up. That may sound like a stupid design, but it actually turned out very well. There is also a hidden compartment for a nitrous tank if i choose to go in that direction because of some extra space i ended up with underneath the enclosure. I also mean this in the nicest way, but dont you think you are being a little hippocritical being as you turbo'd your RS? I am more or less wanting the power to have it if i go out to a track or something sometime, not for everyday use.
Under The Hood:
Interior:
Old 10-15-2007, 04:47 PM
Holset powered 420a
Re: Top End
If you want power then put a turbo on it, you didn't act like you wanted to spend that much money on it so I didn't suggest it. And if you are staying NA weight reduction is a big factor. You say you wanted to go faster well I was just letting you know that by adding weight you are making it a little slower.
It may only weigh 5lbs over the stock equipment you removed but if you removed that weight and didn't replace it then you could have lost about 20-30lbs. I cant say to much considering I have a system to.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-15-2007, 07:10 PM
Re: Top End
He boosted his RS more for speeds under 120 mph I'm sure the way he's talking. There is no point to go any faster unless you do it on a track like you said, but unless you have extensive mods you won't even get close to those speeds in your RS in the 1/4.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-15-2007, 07:22 PM
Re: Top End
Ok, sorry, i think this is getting taken the wrong way, and yea you are right i really didnt want to spend a lot of money, i guess i was just trying to get some info and see where i could go with this problem. I guess i just want to know my car can hit a higher speed and have the power to do so if i ever had the opportunity to do it. Does that make sence? I think i kinda made myself look like an idot. Sorry again if i pissed anyone off, & for the confusion, But thanks for the info & opinions.
Under The Hood:
Interior:
