Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-14-2007, 03:33 PM
floresmaxima floresmaxima is offline
Engine wash
Hello Guys,
I have a 96 maxima and need to know what's the best way if any to wash an engine. My engine is all dirty and grease including my alternator where I can see all the dirt in it and I want to wash everything off any ideas.
thanks
Old 10-15-2007, 04:01 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Engine wash
Carburettor non electronics engines, pressure wash is mainly good. The wash should not be pointed directly into bearings, seals. Oil sludge collects dust /obstructs cooling causing untimely engine/tranny wear. My cleanup: hot engine, first sprayin dissolvent onto just about every place(diesel fuel or whatever non too aggressive solvent) after 15 min, before it dries, the wash.
The alt benefits from special wash: http://www.cardomain.com/ride/748507/23
Low voltage signal paths in computer controlled vehicles cant tolerate 'any' water (luckily most bits are well shielded). Pressure wash is precipe for incredible pain - still has to be done sometimes. As water gets into components which may never become dry, resistance changes via water can cause intermittent problems for next 6mths depending on ambient temp humidity plus variety of variables. I washed my engine 4 yrs ago, check out the TPS circus... http://www.cardomain.com/ride/748507/6
As my 80k engine doesn't leak at all (yes, cam/crank o-rings replaced), I dont wash it with water but use pressurized air, rags to clean. Maybe sometime in future it has to be washed, I am afraid. Then I'll try to shield any electrical components (not alt), try not to point the pressure into x components (next to impossible). My son has to wash his awfully dirty engine once a year at my garage (yes, eurobean Citroen, leaking like all healthy GM's) - and so far has successfully driven home with the clean engine Maybe he is lucky (with a citroen!?) or I am unlucky. One has to try.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 10-20-2007, 10:48 AM
SuperStock96 SuperStock96 is offline
Re: Engine wash
Dollar General Degreaser and a tooth brush. Really.
Just a bit better than stock: Berk Intake w/ Apexi Filter, Cattman Y-pipe, FastCat, Cattman Catback Exhaust, TS ECU, Various Lighting Changes.
