Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-14-2007, 01:48 PM
pontiacfreak_81 pontiacfreak_81 is offline
Send a message via AIM to pontiacfreak_81 Send a message via MSN to pontiacfreak_81 Send a message via Yahoo to pontiacfreak_81
Question question about seat in 97 bonne.
I have posted this before and got absolutely no answer, so here goes again...could someone PLEASE tell me if it is possible to switch out my manual adjust seat for a power seat???? and if so what steps i need to take to get it done...ANY INFO would be appreciated...thanks
Old 10-14-2007, 10:40 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Re: question about seat in 97 bonne.
Sure you can change out the seats no problem, they will line right up. But before you do you might want to look and see if the wiring harness for the seats is hidden somewhere under the carpet. If there is no harness from the factory, have fun. That is if you do want the power seats to actually work.
Old 10-15-2007, 12:34 PM
lol yes i do want them to actually work, and there is a harness laying underneath each seat, i assume they are for power seats as they arent plugged into anything. so i will give that a try, if they are not for the power seats do you have any suggestions on the best way to rig the wiring to work??
Old 10-15-2007, 04:34 PM
Well if the harness does not go to the seats, you'll have ALOT of wiring to do. I would definantley get a wiring diagram (preferably from a dealer, NOT a Chiltons or Haynes). You will atleast be able to see what your up against if nothing else. I imagine you would have to wire up some relays and power up another circuit in the fuse box. More than likely there will be a spot reserved for the power seat circuit. But hey check this out, before you do anything, go out to your car and look at that wiring harness that is under the seats. How many wires are on that harness. If there is only 2 wires per harness I bet you it might be for heated seats.
